Book Now
Click to Top
Spacer
Treatments
Bridges
Bridges
If you require a more extensive restoration than a crown or have more than one tooth that needs to be repaired, a good solution is a bridge. Bridges are usually made of a precious metal base which gives them a solid structure and makes them hard-wearing. If you need a bridge in your smile line, porcelain is usually added to the base to make it look more like real teeth. A bridge helps to strengthen the prepared teeth and makes chewing and eating easier because they are fixed and can't come out.
Some bridges can also be fixed to your jaw with dental implants, if you have several teeth next to each other that are missing.
Once you have a bridge fitted, you will have to take extra care of your daily hygiene regime to ensure it stays plaque free and that you can prevent bad breath.
Before
Before
After
After
Existing bridgework had failed and was replaced with new bridgework shown above
Contact Us
I consent to my personal data being collected and stored as per the Privacy Policy.
I consent to my personal data being collected and stored for the purpose of marketing communications.
To prevent spam, enter the characters as shown in the box below.
Verify    Create Image Emailus
    Testimonials Testimonials Testimonials Testimonials Testimonials Testimonials Testimonials Testimonials
  • British Academy of Cosmetic Dentistry
  • Zoom Teeth Whitening
  • The Wand - Pain Free Dentistry
