Book Now
Click to Top
Treatments
Extractions / Oral Surgery
oral surgery
One area of speciality areas within dentistry is known as oral surgery and this applies to procedures of a surgical nature, such as the extraction of teeth or wisdom teeth. Oral surgery requires additional training in techniques to perform procedures with care, helping patients to be able to use their teeth and mouths again.
If you have advanced tooth decay or an impacted wisdom tooth, you may require oral surgery to have them safely extracted. Depending on your particular case and the severity of your problem, we will either carry out the treatment in-house or refer you to an oral surgeon.
It is important to always get the advice of a dental professional if you are worried about any of your teeth. Never attempt to pull out your own tooth out at home as this could cause a more serious problem for you. Dentists have the right equipment and sterile environment in which to perform this type of procedure with the utmost care and your recovery can be fairly quick. In the case of wisdom teeth extractions you may have some swelling after the procedure and discomfort that can be eased with over the counter painkillers.
Contact Us
I consent to my personal data being collected and stored as per the Privacy Policy.
I consent to my personal data being collected and stored for the purpose of marketing communications.
To prevent spam, enter the characters as shown in the box below.
Verify
  • British Academy of Cosmetic Dentistry
  • Zoom Teeth Whitening
  • The Wand - Pain Free Dentistry
